Wiring for 2 amps...
agarabaghi
Right now I have always a single amp setup in my truck. I have 0/1 awg coming from the battery with a 80amp fuse by the battery terminal. I had to trim down the wire so it would fit in the 4awg termianl on the amp. My next setup is going to be dual amp setup so I had a few questions.
The current fuse by the battery is the normal AGU 80amp fuse which is enough for 1 amp, but now that im going to be running 2 identical amp I need to up the fuse size. Since AGU doesnt go higher than 80amp Im guessing I need some kind of ANL inline fuse holder for that part.
Something like this:
Tsunami FBW901-MANL 1 Position 4 or 8 gauge in/out Mini-ANL Fuse Holder Bright Nickel-Plated...
If i was put find an infline fuse holder and put 160amp fuse there and then use a fused distroblock in the trunk to split the 0/1 AWG to (2) 4awg to power the amps can i get away with using something like:
Tsunami TSFDB2-MANL Mini ANL Power Distribution Block with One 0/4 Gauge In & Two 4/8 Gauge Out - TSFDB2-MANL
with (2) 80amp ANL fuses in it.
I would do the same for the ground (minus the fuses)...
Am I missing anything?
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
