wiring an underbody kit
Jordantyler
well im gettin an underbody kit and i was wondering how the easiest way to install..
is it hard?
how do u install the neons under the car?
i have the kit,d. block,switch, and everything i think i just need to get some wire i have speaker wire but what kind would be best to use?
any advice or suggestions would be great
thanks
I run interior and exterior neons on my 2000 Grand am, I linked my 12v. power supply on my accesory supply on the fuse box, when you mount your lights try to put them where (NO) road debri or rail road tracks is going to take them out..... hence don't put them behind your tires, I mounted my side lights on the side of the chasis, where it faces down but is above the lowest point of the body. front light is mount inside of my air ****..facing down..... I also found out the hard way to check and make sure you are allowed to drive your car on the street with the lights on!!!!! Sux when the pull you over! I keep all of my neons on switches so that I can turn them on or off as needed!also might seem stupid but make sure the lights or on constant and not by sound activated.
i recieved the neons in the mail yesterday they are street glow 4 tubes.. with clamps to hold the tubes together and a block i guess where u install the wires.. i bought a switch it has the 3 prungs on the back now how do i ran the wires and where should i put the ground :wtf2: i need help bad yall //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanks guy i apperciate it..
the block is a transformer //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif, if you install it right you should be able to get a ground from the frame of your car. bassic;y you run it as a circle in a way wire from the transformer to the first tube, and then 1st tube wire to 2nd tube so on and so forth, you get the idea. if u need anymore help. feel free to pm me
Is it illegal 2 drive with them on
also how much drain does it put on ur battery
Jordantyler
Jordantyler
arkansas
greendog
BP1Fanatic
BP1Fanatic
