Wiring 4x 6.5 cvt subwoofers.. to a Rockford Fosgate Punch P450.4
  • 2
amp specs
The kickers are 2ohm svc i believe
can handle 150rms each
So i was thinking of wiring it all at 2 Ohm
And switch the amp to 2 channel mode, and bridge the channels
Or would i be better off
Bridging two channels and wiring 2 subs to 2 ohm?
And doing that for the other subs to?
Its stated that in 2 channel mode itll do 580rms? I dont know if thats at 2 ohms though or 4.. and 4x150 is 600rms so the speakers would be maxed then...or would it be better off under powering them?
My set up is in a 95 eclipse gsx
I have 6.5" Memphis M Class Synchronous Components [15-MSYNC6] as my front stage
and planning to use the 4x kickers for midbass..
and i have a 15" kicker l7 for the good stuff
You need to find out *for sure* which 6.5 CVTs you have: 2-ohm or 4-ohm?! Use a DMM to measure ohms if you need to. Discussion is a waste of time until you can tell us this with 100% certainty.
Your amp can only drive a 4-ohm load bridged.
*IF* the subs are SVC 2-ohm like you think, then wire 2 of them *in series* for a 4-ohm load and connect them to 2 of the amps channels bridged. Wire the other two subs in series and bridged off the other two amp channels.
Crutchfield, sonicelectronix and rockford fosgate all have good sub wiring diagrams if you don't know how to wire two subs in series. (or search this forum)
BUT FIRST confirm what impedance subs you have. If they are 4 ohms my advice will be completely different from above.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
229
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
296
463
420
autocrossn
autocrossn
United States
Jepalan
    May 24, 2024
    May 23, 2024
