wireing, ohm's questions, precision power pc21400? ? ? help me
neighborstree
pa
ok so im building a wall in a acura integra.
4 15" orion hcca dual 2ohm subs
i planned on doing 4 precision power 21400 power class amps. one amp per sub. but there so old school that i cant find the amps, ive got 3 so far and one is busted, so im going to send it back to the ahole from ebay that sent me a smoked amp. so im probly going to run 2 subs per amp and use the 2 good ones i have. ok so heres my question
the ppi/precision power pc 21400
its rated at
2 x 350W @ 4 ohms
2 x 700W @ 2 ohms
1 x 1400W @ 4 ohms bridged
THD: 0.02% (4 ohms)
Freq. Response: 4.5Hz ∼ 100kHz (±0.5dB)
S/N Ratio: 115dB
Damping Factor: >500
Max. Current Draw: 230A
Fuse: External 160A
Dimensions: 25.75" x 8.9" x 2.24" (65.4cm × 22.6cm × 5.7cm)
Manufactured in 2000
so i guess what my question is is that if the amps stable 2x700 watts at 2 ohms, why is it not stable at 2800 watts at 2 ohms bridged. or am i wrong ? lol
You are correct, they are only stable to 4Ohms bridged or 2Ohms stereo. 1400 watts is all they were designed to produce. I have seen them run at lower impedance but you would be putting the amp at risk to do so. Have you tried them yet with a stable load?
no, likle i said my plan was to do 4 subs, 4 amps.. well 5 amps, one for the highs but were not talkin about that lol., so what i was asking is if the amps able to produce 700 watts X2 stereo, i was curious what would happen if i was to run 2 15's off one amp bridged witch will give the amp a 2ohm load.. i dont see my subs even moving with 700 watts each lol.
If you bridge an amp to a two ohm load you are effectively putting a one ohm load on the amp. Which is why you see amps rated to two ohms stereo and four ohms bridged. Your amp will do 1400 watts RMS, (700x2@2ohms or 1400x1@4ohms). If you bridge it to a two ohm load it will "try", for lack of a better word, to make 2800 watts. It can't handle that kind of current flow and would either go into protect mode or smoke.
neighborstree
neighborstree
pa
Bake
michigan born
    May 14, 2026
michigan born
    May 14, 2026
