Wire nuts?
Uh wires... You mean i shouldn't be twisting wires together? I have 2 DVC 4 ohm subs and currently have it setup for a 1 ohm load. I only have 1 terminal cup going out also. I'm scrapping that and setting it up for 1 ohm.
Um i don't think people use them because is usually goes into the box via a connection box. Than another piece of wire goes from that to the sub. I don't know why you would even need them. Also some use a wire that goes from the sub thre the box to the amp in one wire with a hole for the wire.
Now, where is the terminal cup?
maseyferguson05
maseyferguson05
Mass
brian84corvette
