Wire Gauge Question
anger
Feel like this is a noobish question and has probably been answered, but I had to rebuild my box and need some answers.
I've got a 1000w Mono Fosgate Amp pushing 4 12" Punch HE's. When I opened it up they subs were "daisy chained" together w/12 gauge wire. I need to know if 16 gauge is sufficient or if there would be a more efficient way to wire them together.
Any Help Is Appreciated or Direction to Someone Who Can help
I understand it's not the best choice, but..i guess what i'm wondering is what's the downside to the smaller gauge?
and is that the proper way to wire the 4 subs together?
---------- Post added at 11:45 PM ---------- Previous post was at 11:44 PM ----------
i've got a bunch a 16g (and not much $) is why im curious
considering you said 1000 watts and 4 subs is roughly 250 watts per sub with likely a less than 4 ft run to your subs. i'd say you're okay right now but at some point you should really look into running good 12 gauge or 10 gauge.
Guess I'll be picking up some decent 12 gauge. Don't wanna be unsatisfied and have to open it up again.
Subs are 8 ohms and were wired like... + & - running from box terminals to sub 1, then same from sub 1 to sub 2 and so on.. is this all good? or should it be diferent?
Wire them in parallel and it should end up at a 1 ohm load. All the plus's summed together and all the negatives summed together to the box terminal.
---------- Post added at 11:10 AM ---------- Previous post was at 11:09 AM ----------
If you really do have a lot of 16 gauge wire than just run, two runs of it to each speaker...
last i checked four 8 ohm subs in parallel resulted in a 2ish final, lol. Op, first look up the minimum rated impedence load your amp is capable of handling. Then,wire them in parallel. Then, use a dmm to find the final ohm load to be safe. Make sure its at or above the lowest load your amp is stable at.
Exactly what I was trying to get at !
soldering wires and need more length than was already used
---------- Post added at 11:37 AM ---------- Previous post was at 11:36 AM ----------
Thanks for the input. Amp is stable at 2 ohms. 'Bout ta start
anger
anger
Ventura County, CA
anger
BP1Fanatic
BP1Fanatic
