comp subs wont flex anything
kikersallday
6
ohio
i have 2 12" kiker competitions with 1 2050 watt volfenhag amplifier i have my power and ground wire ran with 8 guage wire subs are ran with monster wire they hit pretty hard but my trunk wont even flex when i have them cranked and i see people with other less quality subs flexing everything. i run them at 180hz the other two options are 80hz and 120hz. i have the base boost up the low pass all the way up high pass off amp is set to lp and gain is half way up. what am i doing wrong i keep hearing people say these subs should be bad a$$ and flex my trunk lid at least. btw there in a sealed box no air leaks at all period box has no water dammage or cracks and is carpeted.
i have my bass boost on the amp turned up i dont have a remote boost hooked to it yet cant find one for sale for my amp. i have the bass cranked on my head unit as well
i thought it was a problem with my wiring so i posted it here. if you want me to post tech here than fine my left positive and right negative bridges dont work on my amp where can i take it to fix it?
kikersallday
kikersallday
ohio
av83
BP1Fanatic
BP1Fanatic
