winisd error, anyone care to look and help?
You must enter them in a particular order;
This is the recommended method for entering driver parameters [if at any point you need to change the unit of a parameter simply click on the displayed unit and it will change]:Enter Mms and Cms which results in Fs being calculated. If Mmm and Cms are not known enter Fs. If Fs and Mmm or Cms are known enter Fs and the other known value.
Enter Sd, Bl and Re. This will result in more auto calculations being made, but Qms and Qts will be blank. If Re is not available, go ahead and enter Sd and Bl.
Enter either Qms or Rms, whichever is available, generally Qms is available.
If Mms and/or Cms were not provided for input, now input Qes. This will cause some other fields to auto calculate.
Enter Hc, Hg and Pe if available. These are not required, however Pe (RMS Power Rating) will give a good idea of how much power signal input to model with.
Enter the number of voice coils. NOTE: Drivers using dual voice coils may cause the Bl and Re parameters to change when changing the connection wiring from parallel to series. Be sure to monitor these when changing the connection option, but WinISD should automatically change these values properly.
Correct Znom (nominal impedance) if needed. Many times this will change to 6 and should be 2 or 4... or the ultimate resistance (in ohms) you intend to run based on the voice coil configuration and your connection setting (parallel or series).
Enter Xmax and any other missing parameters if known and continue. DO NOT change any of the blue auto calculations. If they are only slightly different, this is okay. If they are off significantly, contact the manufacturer or vendor of the driver.
I am inputting driver info and get this error. not sure what it hates, but it looks like it hates everything. here are the SSTY in advance
yeah it ***** sometimes put in the 1st 2 q's then the fs and 3rd q should come up on it's own, highlight each q and fs after putting in the 1st 1 start at left.. theres a video on u tube
Thanks guys. I deleted the data and started over. I guess some of the drivers specs were off which caused the errors. What's odd is that I have modeled lots of drivers and this was the first time I got those errors. I think winisd was just being cranky. lol
Now I just need to figure out why this version of winisd looks so different from the version I had not to long ago. My memory hates me.
You have to know the signs for winisd. IMO, it really comes down to knowing what you’re doing. Some woofers don’t model well in winisd, at all.
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
Clear iPhone from Pioner memory, clear Pioneer from iPhone memory. Power both off, wait 30 sec or so, try reconnecting.
I wires the sub and checked it. It is at 2ohm and the speakers are at 2.5 from what the manual said
910
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
200
yourconfused
yourconfused
ATX
yourconfused
    Apr 28, 2024
    Apr 28, 2024
