Will this sub work?
  • Thread starter tvbuster
  • Replies 0
  • Views 385
tvbuster
Currently I have two MA Audio subs and a MA audio amp. They are these ones: Subwoofer Size 10"
Voice Coil(s) Dual
Impedance (per voice coil) 4 ohms
Peak Power Handling 1000 watts
RMS Power Handling 500 watts
Woofer Surround Reinforced Ribbed High Foam
Sensitivity 86.87 dB
Frequency Response N/A
Top Mount Depth 5.8"
Cutout Diameter 9.3"
4 Channel High Performance Amplifier
4, 3, or 2 Channel Operation
1000 Watts Power Output
500 Watts x 2 Channels @ 4 Ohm Bridged
900 Watts RMS / 225W RMS x 4 Channels @ 2 Ohm Stereo
125W RMS x 4 Channels @ 4 Ohm Stereo
Selectable LPF/FULL/HPF Crossover
Variable High Pass Crossover Frequency: 50Hz-250Hz
Variable Low Pass Crossover Frequency: 50Hz-250Hz
Variable Bass Boost 0-18dB @ 45Hz
Adjustable Gain Control
3-Way Protection Circuitry (Short/Overload/Thermal)
Power and Protection LED Indicators
Full MOSFET Circuitry
High Level Speaker Line Input
Low Level RCA Input
2 Ohm Stereo Stable
Mounting Hardware Included
Dimensions (L x W x H): 13" x 10" x 2"
Suggested Retail Price: $349.99
Full 2 Year Warranty
One of my subs is blown and the other is has a cracked cone... I'm looking at replacing only one of them but if I have to I will replace both.
I am wondering if this sub will work with my current amp and can I use one of my old MA Audio subs and only one new sub?
Power Handling, RMS 275 Watts
Power Handling, Peak 1100 Watts
Sensitivity 94dB
Frequency Response 25Hz - 400Hz
Impedance 2 or 8 Ohms
Mounting Depth 5-7/8" (149mm)
Cutout Diameter 9-1/4" (234mm)
I don't know because my MA Audio subs are 4 OHM and these are 2 OHM or 8 OHM... I just don't know and am new to all of this.
thanks!
tvbuster
tvbuster
boston, ma
tvbuster
