Will this set up work with 4ch amp + sub bridge
bradl79
ok i am trying to get an amp for my stock stereo, my setup
2CH Front Speakers Auditor RIP-165c
Max. power : 180W
Nom. power : 50W
Nom. impedance : 4 Ohms
2ch Bridge: Kicker TC104
10" Single Competition (Comp) Series Subwoofer
Power Handling:
Peak: 300 watts
RMS: 150 watts
Enclosure impedance: 4 ohms
would this AMP work:
Alpine MRP-F300 4-Channel 300 Watts Amplifier
50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
150 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
Crossover: 50Hz-400Hz, -12dB/oct. (Low-Pass/High-Pass); EQ (Equalizer): Bass EQ (Fixed Frequency): 50Hz +12dB; Subsonic Filter: 15Hz (Fixed), -18dB/oct.
Amplifier Type: Class-A/
or would u recommend another amp if not powerful enough? thank you.
i am not looking for a bass shattering sound, more clean sound, am i better off just doing fronts and rear with aftermarket speakers or to do the fronts and bridge a sub with that set up? also can i go up on the amp so if i do decide to upgrade speakers/subs? thank you all.
If this is the only amp you have, then use it for fronts and subwoofer. This is a standard setup.
bradl79
bradl79
NLR
zako
