Will this amp/ set up run at .75 ohms?
dragonfister
Amp = Exile 2500.1
My 2000 golf consists of 1/0 guage all around , a yellow top and stock 90 amp alternator
Sub is a single 13w7 and i want to wire it to .75 ohms then just turn the gain way down.
Or would i be better off running it at 3 ohms and getting say 1200 rms, The sub is in a 2.8 cf after port and sub displacement tuned to 28 hz with a 4 inch areo port.
If you are not planning on using the power you would dissipate at .75 ohm, I would just wire at 3. If you lower your load that low there is a good chance the amp will get really hot. I have had no expereince with it personally, but that is a pretty substantial amount of current.
dragonfister
dragonfister
Canada
knightsdaze
