Sold will paypal someone $5.00 right now
vickman08
for a box design for 2 05 xxx 15's want it to be 4 cubes ea(internal)tuned to 27hz,subs up port back within these requirements 48" 33" 17" with around 130 sq in of port area...will even throw in an extra $5 if you would give me ur number to call u incase i run in to some hurdles(only if need be...will not ask for it until i need help)also u have to have some refs on here...its an easy way to make some money for some something i know im too lazy to look up lol...lmk asap
thats why i was thinking the lower tuning...also everyone whose uses their xxx's in an "sq" setup so far has told me to tunes low as possible....(ie 30hz.28,27 etc)
4 cubes would be choking a pair of XXX and tuned that low in that size box with that much port area would be rough fitting into the dimensions listed. You'd probably get alot better performance out of just 1 in an optimal enclosure, and for 27Hz, I recommend flat response and low tuning like that. 35Hz will get louder but the drop off rate and 3dB down point will cause lack of the low extension the 05 XXX has potential for. IMO, 4 cubes @ 27Hz would sound very nice with only one and you don't run the risk of listening fatigue caused by non-flat response. PS, the lower you tune it, the better control the sub will have during high excursion and you wont run the risk of snapping a lead like som many have on the 05's
vickman08
vickman08
fort knox
tragic_magic
