Will adding 2nd battery allow me to run more powerful mono amplifier
The service dept at the local Toyota dealership said the increased current might damage the vehicle electronics.
You would have to be utterly ignorant about anything related to auto electric systems to make a statement like that.
Current is provided on demand by the electrical accessories -- it is not a "force-feed" situation.
The big 3 simply reduces the resistance between components in the electrical system by increasing the cross section of the power and ground wires.
Less resistance means a little less voltage drop and slightly more efficient flow of current.
Hopefully that dealership knows more about their cars' engines and transmissions than they do the fundamentals of their charging systems.
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
816
Thanks. That makes sense. It sounds pretty good as is.
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
airman
airman
Los Angeles
negolien
