mitchellc123 10+ year member
Ik that you're not supposed to open your trunk when bumping with a sealed box because of the resistance levels but can you play a sealed box in an SUV since there's no resistance?
What do you mean by bottoming?Its usually the ported boxes that sound like **** when the trunk is open.. Alot of people think that the subs are bottoming and stuff, its just cause the air is just blowing in the wind.. close the trunk and all is good..
Ohh okay thank you for the adviceLike the subs are being overpowered, or over peak excursion, its just what the ear hears but usually everything is fine it just sounds that way with the trunk open, i have ran many systems in my old full size bronco, ported and sealed, its a pretty large open area in there, and sealed sounded great. Imo i would go for a ported enclosure in a suv since there is the extra room for it..
Hmm..good to knowI would build whatever box the subs call for.......anyone telling you to build one or th other without knowing the subs is just wrong.
Also it won't matter ported or sealed if the trunk is open (unless you are doing 160 db's and manage to blow a window causing the subs to unload and launch a cone)
Chances are unless you are putting retard power to the subs, you will never bottom them out in a sealed enclosure.
