why that was nice
Should i start using crystal meth?
  • Sure...its not that bad...
    Votes: 93 62.0%
  • Just say no!
    Votes: 57 38.0%
  • Total voters
    150
Details:
# The micro-DVI out is single-link only, meaning it can drive a 24-inch monitor, not a 30-inch. There's no DisplayLink converter / adapter yet.
# Remote Disk comes on the install DVD -- ironically, Apple expects you to carry around a DVD to install so you can access someone else's DVD drive. Righty-o.
# It uses MagSafe, but the new connector is angled 90-degrees to stay out of the way. You can use a regular MacBook / Pro adapter, assuming you don't mind the side being propped up a little (or hanging off the edge of a table). You can also use the MBA's 45w adapter on other machines -- the plug should still fit, but the adapter may not have enough juice to charge AND power a running machine.
# The MacBook Air superdrive needs special hardware in the MBA to work -- Apple wouldn't tell us if any other devices will be able to use the thing, but we imagine the ~500mA USB outputs won't be enough.
# The 64GB SSD option is +$1000 -- but you probably already knew that if you hit Apple's site.
# The speaker is mono only (not stereo), so your audio output will suffer a bit. The audio comes out of the keyboard holes in the right side, and it sounds a little funny.
# The port array folds down, it's not a door over ports that don't move. It feels extremely sturdy.
# The only audio input will have to be via USB or the built-in mic.
# The machine comes packaged with micro-DVI to DVI and micro-DVI to VGA adapters, but you have to snag the S-Video and composite adapters separately
faulkton
faulkton
neverland
natisfynest
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
