lilmaniac2
Ask Me about SI Mag V4!
To the positive but not to the negative, the Neg from the alternator is grounded to the frame which the battery connects to.
What kind of degree can you get in 2 years?
What happened to the origional lolmaniac?
ps, it isnt connected to the frame, it is connected to the engine block which is connected by a wire to what.... THE BATTERY!!!
Don't believe me , go pull your motor and see.
Wanna know why there isn't a wire used there? Because the engine block is made of a higher grade metal with a lower resistance and works better for conducting than the steel used in frames
