Why isnt my system loud?
how can i make it where its heard for a block or two because my budy has 900 watts to a memphis m3 and it pounds super hard.
There are many factors that are involved in this. The main ones being: enclosure, amplifier / power, subwoofer(s), and vehicle. If you have a truck, the box will not be able to be that big. That being said, you are pretty much stuck with shallow mount and smaller subwoofers. When people say that size matters to be loud, it really doesn't. The only thing size changes is mainly sound quality and air movement due to cone area. I've heard two (2) 10's hit harder than two (2) 18's, and metered significantly louder. The key factor you're looking for is quality of the sub. Personally, when dealing with Memphis, I would only go with the Mojos (which I believe you have, D4?).
Also, what amp are you pushing them with? Your 600W amp is more than likely pushing around 300W, if that. A lot of amps are heavily overrated, especially lower end stuff. Old school stuff, on the other hand, can get pretty crazy (depending on the brand).
Also you have a preference, if you want your bass to be heard from a couple blocks away or if you want your car rattling from a couple blocks away. You're going to be louder if your box is tuned higher in most cases, but the bass is going to sound cleaner and travel further if you're tuned lower. Also realize that some subs tend to get louder as you go further from them up to a certain distance. Make sure you're not tuned too high or too low, as that would ultimately make the result of your sound garbage. I'm assuming you're not competing.
Please provide:
Vehicle
Type of amplifier you're running
Whether or not you're running a factory head unit
Box volume
Box tuning
Im running a memphis pr 12d4v2 with a memphis mc1000d at 2 ohms so 600 watts and it does rated at 12v. My sub is in a long slot ported truck box about 49in long 5 in wide and 14.5 in tall.
Vehicle 1998 ford explorer sport
Type of amplifier you're running memphis 16-mc1000d
Whether or not you're running a factory head unit ,aftermarket pioneer
Box volume idk long truck ported
Box tuning unknown
You have an SUV, why the hell are you using a crappy truck box???
You wanna be heard? Then use that hatch area for some cone area! Get a nice box with a pair of 15s on 1k to 1.5k and you'll definitely be heard blocks away.
But if you are wanting a system to only be able to be heard from a distance, and not your own personal enjoyment, then get out of this hobby cause it's people like you that make everybody else look bad.
new box and new sub. That PR isnt going to do anything with added power above 500w. Its a very basic entry level sub. The m3 is quite a bit better. A box often times will be the most efficient, or in your case inefficient, piece in a setup. Build a custom box and it will do the PR alot more justice
pr festiva was doing 46's with a memphis pr 12 on
they are entry level but will get loud if you know what you're doing
The difference is he did that burping a relatively high tone. It had nothing to do with feeling loud, being heard miles away, etc. Different applications. SPL vehicles don't necessarily "feel" loud. It depends on what this kid is after.
If I was you, I would strive for your system to "feel" loud and sound good. Forget being heard miles away.
Please provide:
Vehicle
Box volume
Box tuning
Wrong on so many levels. First of all sub size doesnt affect sound quality at all. A 15" can sound just as good as an 8" sub. An 8" sub can sound just as bad as a 21" sub. Its dependent on a number of things. Mainly box, tuning, quality, etc.
Sub size does affect loudness. More cone area = more movement with everything else identical including sub Xmax.
southport2014
southport2014
Indianapolis, IN
southport2014
