Why did my sub blow?
eclipse3130
Re-do haha.
New 2012 model alpine type r 10" with an alpine mrx-m100 amp(1000 watts rms to the sub) Bass boost setting on 0. Gain professionally set + turned down a hair from there. Properly "broke in" 5-8 hours of nothing more than 1/2 settings and volume. It just blew out today at about 16-20 hours played. Was playing it in 80 degree weather heavily. All deck bass settings on max with volume about 3/4th way up. What really caused my sub to blow.. Was it just a bad sub or what. And yes the gain was properly set.
"All deck bass settings on max " i would say that is your problem right there
^^This. Your gain on your amp may have been set correctly, but your signal was more than likely clipped being sent out of your HU, well before it even got to your amp.
Yeah but I had the guy specifically set the gain when the deck was on max, that was the point haha, not going to listen to it on low deck settings. And like I said I turned the gain down a hair from what he set it at.
correct me if i'm wrong, but if someone set the gains with HU bass at 0 and 3/4 volume and you max the bass even on the HU, you basically defeated the original gain setting? or perhaps loss of cone control below vent tuning?
I set the gains with HU bass at max, and volume at 32/35
Your amp is not the only device in your signal chain. Any processing device has the possibility to cause distortion, or clipping. In this case, you turning the bass settings all the way up more than likely fed a distorted signal to your amp. Your amp amplifies what it is fed. Your amp itself may not have been adding any distortion, but how do you know the signal coming out of your amp wasn't distorted? Did you test it in any way?
And how exactly did it blow? What did it do?
eclipse3130
eclipse3130
Seattle, WA
hispls
