Ok so my 89 maxima blew her ****** so its time for something new I could use a downpayment more than a system right now so its all up for sale:
Rainbow Audio SLC 265 2 way components. Used for about a year and a half never pushed to hard $175. Heres the specs:
Max. input power: 150W
Sensitivity: 90dB 1W/1m
Frequency response: 50 Hz - 22.000 Hz
Impedance: 4ohm
Silk Tweeter: 22mm
Crossover: 2x 12 dB / Oct.
Image Dynamics ID-Max V2 D4 with a blown voice coil. Was going to ship back to ID to be reconed and upgraded to V3 but now need the money. $150 (Both maxes can be reconed to either d2 or d4 voice coils so after 2 recones both woofers could be identical.)
Image Dynamics ID-Max V3 D2 with a blown voice coil. Was going to ship back to ID to be reconed but now need the money. $150 (Both maxes can be reconed to either d2 or d4 voice coils so after 2 recones both woofers could be identical.)
Bob Carver designed sunfire 12" sub designed for home theater use but I used it in my maxima. designed for an 11" cubed box with 3300wrms I had it in a 1.5 cubic ft. box with 1400wrms and it still got well over 1 inch excursion and sounds great doing it. It is a flat cone single 4 ohm coil sub with double stacked magnets works and sounds great. $175
Memphis MC-300 amp used for about a year and a half to power the rainbows great clean undistorted sound. $175 Heres the Specs:
Price & Contact: MSRP $410 USD; 901-525-5711, http://www.memphiscaraudio.com
Operating Voltage: 14.4 Volts (11-16 Volts allowable)
Rated Power @ 13.8 Vdc, 0.03%THD: 150 Watts x 2 into 4 ohms, 240 Watts x 2 into 2 ohms, 480 Watts into 4 ohms bridged
Measured Power @ 14.4 volts, 0.035 THD: 164.6 watts x 2 into 4 ohms, 272.6 x 2 into 2 ohms, 545.2 watts into 4 ohms bridged
Current Draw @ Max Power: 31.1 amps @ 4 ohms stereo, 55.2 amps @ 2 ohms stereo and 4 ohms bridged
Efficiency @ Max Power: 4 ohms Stereo: 73.5% @ 4 ohms stereo, 68.6% @ 2 ohms stereo and 4 ohms bridged
Efficiency at 1/3 rated power: 4 ohms Stereo: 38.6% @ 4 ohms stereo, 36.0% @ 2 ohms stereo and 4 ohms bridged
Amplifier Weight: 8.5 Pounds (3.86 kg)
Amplifier Dimensions: 6.5 inches x 2 inches x 15.2 inches (165 mm x 51 mm x 386 mm)
Crossover: Continuously variable 18 dB/octave from 40 Hz-6000 Hz
Frequency response: 10 Hz to 50 kHz
Input Voltage Range: 250 mV to 5 volts
Kenwood X789 Head Unit, used for about a year and a half $120 heres the specs:
CD receiver with built-in amplifier (22 watts RMS/50 peak x 4 channels)
motorized, detachable face with multicolor fluorescent display
Advanced Codec (AC) Drive with Voice Index on Tap offers voice confirmation of digital music folders and files
G-Analyzer measures G-force during acceleration, braking, and cornering
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3, WMA, and AAC files)
System Q EX Sound Control with 3-band parametric equalizer
System E's+ crossover system
satellite radio controls (SIRIUS or XM subscription, tuner, and antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
HD Radio-ready (will control Kenwood's HD Radio tuner)
CD changer controls
auxiliary input
dual-zone audio control
5-volt front, rear, and subwoofer preamp outputs
Bass Management System (B.M.S.) controls the bass boost on compatible Kenwood Excelon amplifiers
wireless remote
clock
CD frequency response: 10-20,000 Hz
CD signal-to-noise ratio: 110 dB
FM sensitivity: 9.3 dBf
Clarion DPX1000.2 Used for quite a few years but still going strong. Same design as the arc audio 1500D-R. Its a class t monoblock tri-path processor amp. $150 Heres the specs:
2 x 175W @ 4 ohms (0.05% THD)
2 x 250W @ 4 ohms (
2 x 330W @ 2 ohms (0.5% THD)
2 x 450W @ 2 ohms (
2 x 500W @ 1 ohm (
1 x 1000W @ 2 ohms bridged (
Optima Yellow top used but going strong, I'll get the model tomorow when I pull it from the car. Would prefer local buyers cause it would be a pain to ship. $80
I will have pics of everything tomorow as everything accept the maxxes are still in my car.
Impedance: 4ohm
Silk Tweeter: 22mm
CD changer controls
auxiliary input
wireless remote
clock
2 x 250W @ 4 ohms (
2 x 450W @ 2 ohms (
2 x 500W @ 1 ohm (
