Sold Whole system for sale: Rainbow, 2x ID-max, memphis, etc
dmcfirestar500
In a truly Maxed out max
Ok so my 89 maxima blew her ****** so its time for something new I could use a downpayment more than a system right now so its all up for sale:
Rainbow Audio SLC 265 2 way components. Used for about a year and a half never pushed to hard $175. Heres the specs:
Max. input power: 150W
Sensitivity: 90dB 1W/1m
Frequency response: 50 Hz - 22.000 Hz
Impedance: 4ohm
Silk Tweeter: 22mm
Crossover: 2x 12 dB / Oct.
Image Dynamics ID-Max V2 D4 with a blown voice coil. Was going to ship back to ID to be reconed and upgraded to V3 but now need the money. $150 (Both maxes can be reconed to either d2 or d4 voice coils so after 2 recones both woofers could be identical.)
Image Dynamics ID-Max V3 D2 with a blown voice coil. Was going to ship back to ID to be reconed but now need the money. $150 (Both maxes can be reconed to either d2 or d4 voice coils so after 2 recones both woofers could be identical.)
Bob Carver designed sunfire 12" sub designed for home theater use but I used it in my maxima. designed for an 11" cubed box with 3300wrms I had it in a 1.5 cubic ft. box with 1400wrms and it still got well over 1 inch excursion and sounds great doing it. It is a flat cone single 4 ohm coil sub with double stacked magnets works and sounds great. $175
Memphis MC-300 amp used for about a year and a half to power the rainbows great clean undistorted sound. $175 Heres the Specs:
Price & Contact: MSRP $410 USD; 901-525-5711, http://www.memphiscaraudio.com
Operating Voltage: 14.4 Volts (11-16 Volts allowable)
Rated Power @ 13.8 Vdc, 0.03%THD: 150 Watts x 2 into 4 ohms, 240 Watts x 2 into 2 ohms, 480 Watts into 4 ohms bridged
Measured Power @ 14.4 volts, 0.035 THD: 164.6 watts x 2 into 4 ohms, 272.6 x 2 into 2 ohms, 545.2 watts into 4 ohms bridged
Current Draw @ Max Power: 31.1 amps @ 4 ohms stereo, 55.2 amps @ 2 ohms stereo and 4 ohms bridged
Efficiency @ Max Power: 4 ohms Stereo: 73.5% @ 4 ohms stereo, 68.6% @ 2 ohms stereo and 4 ohms bridged
Efficiency at 1/3 rated power: 4 ohms Stereo: 38.6% @ 4 ohms stereo, 36.0% @ 2 ohms stereo and 4 ohms bridged
Amplifier Weight: 8.5 Pounds (3.86 kg)
Amplifier Dimensions: 6.5 inches x 2 inches x 15.2 inches (165 mm x 51 mm x 386 mm)
Crossover: Continuously variable 18 dB/octave from 40 Hz-6000 Hz
Frequency response: 10 Hz to 50 kHz
Input Voltage Range: 250 mV to 5 volts
Kenwood X789 Head Unit, used for about a year and a half $120 heres the specs:
CD receiver with built-in amplifier (22 watts RMS/50 peak x 4 channels)
motorized, detachable face with multicolor fluorescent display
Advanced Codec (AC) Drive with Voice Index on Tap offers voice confirmation of digital music folders and files
G-Analyzer measures G-force during acceleration, braking, and cornering
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3, WMA, and AAC files)
System Q EX Sound Control with 3-band parametric equalizer
System E's+ crossover system
satellite radio controls (SIRIUS or XM subscription, tuner, and antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
HD Radio-ready (will control Kenwood's HD Radio tuner)
CD changer controls
auxiliary input
dual-zone audio control
5-volt front, rear, and subwoofer preamp outputs
Bass Management System (B.M.S.) controls the bass boost on compatible Kenwood Excelon amplifiers
wireless remote
clock
CD frequency response: 10-20,000 Hz
CD signal-to-noise ratio: 110 dB
FM sensitivity: 9.3 dBf
Clarion DPX1000.2 Used for quite a few years but still going strong. Same design as the arc audio 1500D-R. Its a class t monoblock tri-path processor amp. $150 Heres the specs:
2 x 175W @ 4 ohms (0.05% THD)
2 x 250W @ 4 ohms (
2 x 330W @ 2 ohms (0.5% THD)
2 x 450W @ 2 ohms (
2 x 500W @ 1 ohm (
1 x 1000W @ 2 ohms bridged (
Optima Yellow top used but going strong, I'll get the model tomorow when I pull it from the car. Would prefer local buyers cause it would be a pain to ship. $80
I will have pics of everything tomorow as everything accept the maxxes are still in my car.
Oh yeah both IDmax are 12's and I'll have pics of everything up soon, my 2 days off work are tuesday and wednesday so might have to wait till tuesday but I'll try to get the stuff out tomorow before or after work (working 9-4 then class 5-9)
The rainbows are not kicks, just the standard sound lines. I just copied the info from the box they came in from Rainbow, so if the box is wrong then I am too. The clarion isn't the best to look at cosmetically not too bad but a few scratches.
I left work early to take advantage of the good weather and pulled the system except the head unit. I'll have pics of it all up tonight after class provided I can find a digicam to borrow.
ID MAX 12 D2 V3:
ID MAX 12 D4 V2 (I just found that the rubber surround on this sub has a smal slit in it but it needs reconed anyway):
And a little comparison between the maxes and the sunfire:
dmcfirestar500
dmcfirestar500
Baltimore, MD
dmcfirestar500
