Sold Whole system for sale: Rainbow, 2x ID-max, memphis, etc
dmcfirestar500
In a truly Maxed out max
Ok so my 89 maxima blew her ****** so its time for something new I could use a downpayment more than a system right now so its all up for sale:
Rainbow Audio SLC 265 2 way components. Used for about a year and a half never pushed to hard $175. Heres the specs:
Max. input power: 150W
Sensitivity: 90dB 1W/1m
Frequency response: 50 Hz - 22.000 Hz
Impedance: 4ohm
Silk Tweeter: 22mm
Crossover: 2x 12 dB / Oct.
Image Dynamics ID-Max V2 D4 with a blown voice coil. Was going to ship back to ID to be reconed and upgraded to V3 but now need the money. $150 (Both maxes can be reconed to either d2 or d4 voice coils so after 2 recones both woofers could be identical.)
Image Dynamics ID-Max V3 D2 with a blown voice coil. Was going to ship back to ID to be reconed but now need the money. $150 (Both maxes can be reconed to either d2 or d4 voice coils so after 2 recones both woofers could be identical.)
Bob Carver designed sunfire 12" sub designed for home theater use but I used it in my maxima. designed for an 11" cubed box with 3300wrms I had it in a 1.5 cubic ft. box with 1400wrms and it still got well over 1 inch excursion and sounds great doing it. It is a flat cone single 4 ohm coil sub with double stacked magnets works and sounds great. $175
Memphis MC-300 amp used for about a year and a half to power the rainbows great clean undistorted sound. $175 Heres the Specs:
Price & Contact: MSRP $410 USD; 901-525-5711, http://www.memphiscaraudio.com
Operating Voltage: 14.4 Volts (11-16 Volts allowable)
Rated Power @ 13.8 Vdc, 0.03%THD: 150 Watts x 2 into 4 ohms, 240 Watts x 2 into 2 ohms, 480 Watts into 4 ohms bridged
Measured Power @ 14.4 volts, 0.035 THD: 164.6 watts x 2 into 4 ohms, 272.6 x 2 into 2 ohms, 545.2 watts into 4 ohms bridged
Current Draw @ Max Power: 31.1 amps @ 4 ohms stereo, 55.2 amps @ 2 ohms stereo and 4 ohms bridged
Efficiency @ Max Power: 4 ohms Stereo: 73.5% @ 4 ohms stereo, 68.6% @ 2 ohms stereo and 4 ohms bridged
Efficiency at 1/3 rated power: 4 ohms Stereo: 38.6% @ 4 ohms stereo, 36.0% @ 2 ohms stereo and 4 ohms bridged
Amplifier Weight: 8.5 Pounds (3.86 kg)
Amplifier Dimensions: 6.5 inches x 2 inches x 15.2 inches (165 mm x 51 mm x 386 mm)
Crossover: Continuously variable 18 dB/octave from 40 Hz-6000 Hz
Frequency response: 10 Hz to 50 kHz
Input Voltage Range: 250 mV to 5 volts
Kenwood X789 Head Unit, used for about a year and a half $120 heres the specs:
CD receiver with built-in amplifier (22 watts RMS/50 peak x 4 channels)
motorized, detachable face with multicolor fluorescent display
Advanced Codec (AC) Drive with Voice Index on Tap offers voice confirmation of digital music folders and files
G-Analyzer measures G-force during acceleration, braking, and cornering
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3, WMA, and AAC files)
System Q EX Sound Control with 3-band parametric equalizer
System E's+ crossover system
satellite radio controls (SIRIUS or XM subscription, tuner, and antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
HD Radio-ready (will control Kenwood's HD Radio tuner)
CD changer controls
auxiliary input
dual-zone audio control
5-volt front, rear, and subwoofer preamp outputs
Bass Management System (B.M.S.) controls the bass boost on compatible Kenwood Excelon amplifiers
wireless remote
clock
CD frequency response: 10-20,000 Hz
CD signal-to-noise ratio: 110 dB
FM sensitivity: 9.3 dBf
Clarion DPX1000.2 Used for quite a few years but still going strong. Same design as the arc audio 1500D-R. Its a class t monoblock tri-path processor amp. $150 Heres the specs:
2 x 175W @ 4 ohms (0.05% THD)
2 x 250W @ 4 ohms (
2 x 330W @ 2 ohms (0.5% THD)
2 x 450W @ 2 ohms (
2 x 500W @ 1 ohm (
1 x 1000W @ 2 ohms bridged (
Optima Yellow top used but going strong, I'll get the model tomorow when I pull it from the car. Would prefer local buyers cause it would be a pain to ship. $80
I will have pics of everything tomorow as everything accept the maxxes are still in my car.
Head Unit is still in the car, I was going to wait to take it out to see if there was any interest, if not I was just going to leave it in the car and throw in some crappy coax's so it atleast had something when I sell the car.
If your interested let me know and I'll take it out.
Pat
Pat
Take some pics of it running in the car, that would add value:D.
I am really interested in it, and I mean it(chk the HU in my sig //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif)
Sorry been working 10hr days the past few days, havn't been able to put another battery back in the maxima to power up the HU for you. Hopefully will be able to in the next few days.
Pat
YGPM back.
I have off work tomorow so everything will be on ebay tomorow.
I also have about 15' of zero gauge I'll be taking out an a distro block I'll be taking out so if anyone is interested in them let me know as well. I'd let them go pretty cheap especially if you buy something else from me.
dmcfirestar500
dmcfirestar500
Baltimore, MD
dmcfirestar500
