Which sub for my MRD-M605 amp: Alpine SWR-1043D or Alpine SWR-1023D
joelx21
As the title says... which sub would be a better choice for my amp?
I'm new to the world of car audio and from what I can see, the main difference between these two subs is that the Alpine SWR-1043D is 4 ohms and the SWR-1023D is 2 ohms.
Thanks,
Joel
Here's the Alpine MRD-M605's specs:
Class D mono subwoofer car amplifier
RMS Power Rating:
300 watts x 1 chan. at 4 ohms
600 watts x 1 chan. at 2 ohms
internal, variable-speed cooling fan
Amp Link for single-cable hookup to compatible Alpine receivers
STAR Topology for cleaner sound
Bass Engine® features:
Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
Selectable subsonic filter (off, 15Hz, or 30 Hz)
Parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition
And now the subs:
Alpine SWR-1023D
10" subwoofer with dual 2-ohm voice coils
Kevlar reinforced pulp cone with Santoprene rubber surround
cast aluminum frame with perimeter venting and radial finned heat sink
frequency response: 26-200 Hz
power handling: 300-600 watts RMS (300 watts per coil)
peak power: 1,800 watts
sensitivity: 83 dB
top-mount depth: 5-7/8"
sealed box volume: 0.5-1.0 cu. ft.
ported box volume: 0.8-1.5 cu. ft.
warranty: 1 year
Alpine SWR-1043D
10" subwoofer with dual 4-ohm voice coils
sensitivity: 83 dB
warranty: 1 year
Our 60-day money-back guarantee
I would suggest getting the D4 subwoofer and wire it like this for a 2ohm load
I agree with above. That generation of type-r was rated for 600watts RMS, good match for your amplifier when wired for 2ohm load.
I'm glad that I asked. Since I was planning on having it at 2 ohms, I figured that the SWR-1023D would be the best choice since it was already at 2 ohms.
With my set up, what's the benefit of going with the SWR-1043D vs. the SWR-1023D?
Thanks,
Joel
Well, we already told you, go with the subwoofer that can be wired for 2ohm impedance. Get the SWR-1043D and wire it as shown on the picture. This is called parallel wiring of voice coils. If you start with dual 4ohm vc subwoofer, the final impedance will be 2ohm. If you got the 2ohm dvc model and wired it this way, the final impedance would be 1ohm, which is too low for many amplifiers.
joelx21
joelx21
So Cal
kramer_212
