Which Setup Would Sound better? - Zane?
  • 2
Mark_ab
The Alpha Male
Which setup would be for effective for SQ? I have two scenarios here.
(a) Infinity Perfect 6.1 in kick panels with an Infinity Perfect Al dome tweet mounted on dash/on door perpendicular to occupants. This is to reduce/eliminate the rainbow effect sometimes caused with kick panels (I've read). The tweet powered by the deck, with the perfects powered by a JBL P80.4 amp.
or
(b) Infinity Perfect 6.1 in kick panels with a Focal 5.25" midbass driver in the stock door panels. Likewise, a JBL P80.4 powering the components, and the midbass.
This is going in an early 90's Chev Z34. Any comments appreciated.
Also (zane), what would you recommend I do for the rear? I was thinking of another set of perfects for the rear stage, but I've seen you do not recommend this. I'm going to have a multimedia system hooked up as well, and would like a nice surround effect. Am I hoping for too much? Is it one or the other? Thanks.
Well, you asked for Zane, we didn't think we were worthy enough. Lol, I'd go with (a), I am not very fond of the idea of having 5 1/4 & the 6 1/2's (i think). I don't see much difference in the two sizes, that's all. Infinity makes very good SQ speakers, I had a pair of 4's with my last system, and a pair of 3/4 tweets. It sounded very good, clarity, loudness, all running off the deck. Some people would swear up and down I had more mid's than I did, until they got in the car, and saw that's all I was running. I think one pair of mid's is good enough, the only upgrade I could say I would go for (midbass) would be an 8" driver. My opinion is the 8's can handle the midbass freq's, much better than the 5 1/4 or 6 1/2's would. So, again I say stick with the 6.1 and the tweets.
Okay, thanks. I was leaning towards the second set of tweets. If need by, I can add a midbass driver later on, if need be. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You may even look into an indash PreAmp EQ that will allow for more control at your finger tips along with an increase of voltage signal...
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
731
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
Mark_ab
