Which Setup Would Sound better? - Zane?
  • 2
Mark_ab
The Alpha Male
Which setup would be for effective for SQ? I have two scenarios here.
(a) Infinity Perfect 6.1 in kick panels with an Infinity Perfect Al dome tweet mounted on dash/on door perpendicular to occupants. This is to reduce/eliminate the rainbow effect sometimes caused with kick panels (I've read). The tweet powered by the deck, with the perfects powered by a JBL P80.4 amp.
or
(b) Infinity Perfect 6.1 in kick panels with a Focal 5.25" midbass driver in the stock door panels. Likewise, a JBL P80.4 powering the components, and the midbass.
This is going in an early 90's Chev Z34. Any comments appreciated.
Also (zane), what would you recommend I do for the rear? I was thinking of another set of perfects for the rear stage, but I've seen you do not recommend this. I'm going to have a multimedia system hooked up as well, and would like a nice surround effect. Am I hoping for too much? Is it one or the other? Thanks.
Well, you asked for Zane, we didn't think we were worthy enough. Lol, I'd go with (a), I am not very fond of the idea of having 5 1/4 & the 6 1/2's (i think). I don't see much difference in the two sizes, that's all. Infinity makes very good SQ speakers, I had a pair of 4's with my last system, and a pair of 3/4 tweets. It sounded very good, clarity, loudness, all running off the deck. Some people would swear up and down I had more mid's than I did, until they got in the car, and saw that's all I was running. I think one pair of mid's is good enough, the only upgrade I could say I would go for (midbass) would be an 8" driver. My opinion is the 8's can handle the midbass freq's, much better than the 5 1/4 or 6 1/2's would. So, again I say stick with the 6.1 and the tweets.
Okay, thanks. I was leaning towards the second set of tweets. If need by, I can add a midbass driver later on, if need be. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You may even look into an indash PreAmp EQ that will allow for more control at your finger tips along with an increase of voltage signal...
11
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
608
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
933
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
Mark_ab
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
