Which Fuse?
You fuse the main power line close to the battery in case the wire shorts out on the chassis.
like so
BATT----FUSE----------------------------------------------------------AMP
..............................^if it shorts out here it will burn your car down to the ground, The fuse will stop that.
for all those who didnt make it pass 2nd grade....
Fuse for the melting capacity of the wire / insulation. If You dont, You will have a very dead & very hot short which could cause You to lose everything in the car to a thick black smoke & fire.
Fuse for the wire capacity.
RumbleNTheTrunk
RumbleNTheTrunk
Liberty, TX
Nikuk
