Which 3 10"'s should i get!?
syntheticwaste
This is the amp i got R.F. p5002 model 2 channel, (im keeping it for now) the specs below.
Its hooked into one 15" audiobahn SE right now.
I am going with 3 tens, i listen to all metal.
I need 3 tens that most shops will carry that will put out a lot more volume than having this one fifteen.
Budget: $550 with a box and labor (found shops to do it for $100 or less)
I have been looking at 3 JL Audio 10"'s w1 model... good choice for A LOT more bass volume and quality!?
If you guys can point me in the right direction... Thanks.
Amp spec's:
1500 watt peak 2 channel amplifier
2 x 250 watts rms at 2 ohm
500 x 1 watts RMS @ 4 ohm
MOSFET power supply
Bass Boost: 0 - 18 dB
*****-ANA circuitry
Frequency Response: 20-300 Hz
CEA2006 Cpmpliant (all specs are lab tested and rated)
Signal to Noise Ratio: >80 dB
Preamp Outputs
Removable Chrome cover
Built-In ATC Fusing
Built-in high and low-pass Crossovers
Remote Punch Bass Boost
Power Indicator and Protection LEDs
THD @ 4-Ohm RMS: 0.08 %
Maybe MAch5 MAW-10's, FI SSD 10's, SS RL-i 10's
but your not going to get 4 ohms mono
+1, I've owned 2 out of the 3 mentioned (RL-i's & MAW 10"s). //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Just go with 2.... 2 jlw1v2 8 ohms .... then you can get a 4 ohm mono load ... that is probably one of the best choices of woofers for the price...
maybe even maw 10s would be a good choice.
thanks for the help im starting to think i might as well get a new amp to avoid any dissapointment. with this amp can i really get that much more power/sheer bass volume out of 3 tens... Can it really get a lot louder than what that 15" is putting out now??? this shit is frustrating.
i know it will sound way ****ing better but shit i need some more volume on the subs, possible to get much more or buy a new amp!? if I get a new amp whats necessary for the subs mentioned so far!? i like your suggestions. thanks
you could keep that amp and run 2 10s as stated.... get either two 8 ohm SVC woofers... OR get two DVC 4 ohm woofers and wire them in series/parallel.
What size is the box on the 15... i've never been a fan of audiobahn, but if you get that 15 in the right size ported box I think you would be extremely satisfied over what I "think" you probably have it in now.
syntheticwaste
syntheticwaste
San Francisco, CA
SplChoice-
