if he has an HO alt. and Big ole battery, he should get about 3000 outta that amp when its crankin big notes... obviously he's not gettin that power on a 60hz note, but at tuning he should see around that...
Power Output at Maximum Volume before Protection:
67.4 volts
77.1 amps
5196 watts
Power supply voltage was 16.5 volts at rest dropping to around 14.5 volts. So consider this a 14.5 volt output rating.
Our clamp meter ran out of steam at 400 amps so we measured efficiency at lower levels:
3294 watts @ 84% efficiency (252 amps draw)
3938 watts @ 81% efficiency (316 amps draw)
4424 watts @ 74% efficiency (392 amps draw)
We didn't have an electrical setup to run 12.8 volt testing available at this time.
now im not saying 3000 on the dot, but he should get close, with 200-250A alt. runnin about 14V
he seems fairly new, you guys know what he's lookin for, he's not gonna understand all these technicalities that i've never seen you guys talk about before
