which 15" best on 3000-4000rms?
which 15" for sql on 3-4k rms?
  • massive audio dmx
    Votes: 2 4.5%
  • fi btl
    Votes: 21 47.7%
  • re xxx
    Votes: 16 36.4%
  • treo ssx
    Votes: 5 11.4%
  • Total voters
    44
let me guess...you use a clamp and a dmm and multiply some figures to get "real world" power? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
What do you do.
How do you figure you can't do 3K
Weak electrical??
I'm just trying to help you RU HIGH now?
I'm very edumacated in the field you are interested in. I have owned 3410s in a folded/loaded horn enclosure. I have been sponsored. I had 418s 20 years ago. I can probably help you when ever you get more level headed and cure the munchies you must have. Nothing wrong with that limb but if you smoke to much you might not realize that a person that can help is being ridiculed by someone that should take the cotton out of his ears and stick it in his mouth. How do you have so many posts? Just talk alot about stuff you don;t know?
What do you do.
Weak electrical??
You do realize music is dynamic right? You then realize this doesnt transfer to real world power? You are familiar with impedence rise yes?
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Yes its more than capable of doing over 3k watts. I dont think he was discounting that. You just wont see that kind of power in a daily system. Same with any other amp.
Oh and some specs of the 3000d, high voltage testing
Power Output at Maximum Volume before Protection:
67.4 volts
77.1 amps
5196 watts
Power supply voltage was 16.5 volts at rest dropping to around 14.5 volts. So consider this a 14.5 volt output rating.
Our clamp meter ran out of steam at 400 amps so we measured efficiency at lower levels:
3294 watts @ 84% efficiency (252 amps draw)
3938 watts @ 81% efficiency (316 amps draw)
4424 watts @ 74% efficiency (392 amps draw)
We didn't have an electrical setup to run 12.8 volt testing available at this time.
Low voltage testing
Measurements:
65.8 volts
49.2 Amps
1.33 ohm calculated rise from 0.6 ohm DCR **
3237 Watts
14.4 volts rest dropping to 10.75 volts
Take that how you may
What do you do.
Weak electrical??
and he says i'm in over my head... don't help him
you havent proved ANYTHING you have stated so far.. i see why you don't like me... cause I find stats, and put people like you in your place
What do you do.
Weak electrical??
i didnt say the sundown wont do 3k....i said in a daily application with impedance rise its not gonna do 3kw.
using a clamp and a dmm to get some figures and multiply them wont give you anything but "apparent" power. this isnt "real world" power, its just a calculated figure. you have to account for power factor if you want any truth to those numbers, or hope for a HELL of a tiny impedance rise.
the higher the impedance rise, the farther off you're numbers are going to be...
edit: oh no, he smokes weed. that means he's automatically a moron. que the pot head jokes. oh, and i already voted for the driver i know can take a 3kw rated amp daily. but then again, i dont have experience with those other drivers
I've been in car audio for 21 years as an installer, shop owner, and am friends with some of the guys from Fi. I have had a 70,000 dollar stereo in my truck. I specialize in system applications and bandpass enclosures. I have lots of tricks with cabinets I can share. This guy said he doesn't get his power all day. I thought maybe he was having voltage issues. I am only trying to help. But since you know so much if you'd like to share I can easily tell you what your spot on about. I'm not trying to bash anyone just be of assistance. Are you getting smart with me? that's what it sounds like. Please explain yourself and don't be a jerk while doing it. If you have something I can learn -- I'm open to suggestions but theres no reason to be a jerk about it. I think you misunderstood something I said and further more you got involved in a conversation that didn't involve you. RU smokin w ignore me? Eat some Cheetos and get back with me. Some people are cranky on an empty stomach
ALL IN GOOD FUN
ALL IN GOOD FUN
Its because nobody gets that power all day. You may have been trying to help but sounded arrogant and were wrong in your assumptions. You can call it getting smart, but I call it educated. Your experience nor who you know impresses me so why even throw that out there.
The real question is why you are getting butt hurt and talking shit when you are wrong?
ALL IN GOOD FUN
music is dynamic. every freq will result in a different impedance rise. none of which will ever be as low as your DCR, even at tuning.
the sundown can do 3kw+. no body is arguing that, the issue is, how snb seems to think a 3kw rated amp will be giving 3kw at every single second of the song, regardless of an impedance rise than can climb into the 2 figure range.
its like the main issue that happened with the kicker zx2500.1 thead, when people actually believed a 2500w rated amp was still making 1500+ watts at 8.9 ohms. it was nothing more than apparent power that was WAY off because there was no accounting for power factor
pinoywitboom
pinoywitboom
Da Big Isle
snb778
