Beginner: Need Help selecting Amp/sub Combo
Shocker207
I'm trying to put together a subwoofer system for my car but I dont completely understand how to select the proper amp for the subs. I was looking at Pioneer Premier TS-W1207D2/4. They have a 400 Watt RMS with 1200W peak power. I plan on running a pair. The amp I looked at was Phoenix Gold RSd1200.1. It can be wired to run 780RMS at 4-ohms (if not 4 then 2). Is this a good match? What would be the proper way to wire it if so? What is the difference in running 2-ohm to 4-ohm? If this is not a good match what would be better? When you run 2 subwoofers does it split the power of the amplifier? Thanks for being patient with all of my questions //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I drive a 03 Jetta so there is plenty of trunk space. I dont want to spend tons, maybe around 500 or less. Yes I would like to run 2 12s. I would like it to have a clean sound. Probably a sealed box.
Ben: I have read and can't find the exact answer I'm looking for but thanks anyway.
everything is already wired because of the previos setup that I had. I dont like it anymore though. I used to listen to alot of rap which it was great for but it can't keep up with the faster beats of rock, tends to drag through sharp bass line. 500 would include just amp and subs
Also from the cars I have sat in I prefer the sounds made by the systems using a sealed box over ported.
My personal pick would be to grab 2 12 ssds and a kicker1500.1 from the classifieds. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif But there are other options.
500 for just amp and subs can get you very nice stuff
Shocker207
Shocker207
Denton, TX
Shocker207
