whay to set amp gains at
There is no easier way I don't have all those tools. I thought it would be easy as. If my amp out outs 50 RMS and speakers are set to 80 RMS then I would set the gain to 70 on the amp
Well your amp has a .2-4v input sensitivity.. so if you ratio that out, it should be barely below half gain i believe.
Assuming you have a 2 volt preout from your HU.
155
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
653
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
746
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
bradl79
bradl79
NLR
d77543020
audiobaun
    May 19, 2024
    May 19, 2024
