I went shopping for a tool like that but was not sure of the diameter and length of the pilot bit and the countersink. Whats the specs of yours and what size screws do you use i.e. length and diameter?^^^^ditto that. Unless you messed up the setup on the tablesaw and the blade isn't square...
The router by far gets the most use. Cutting speaker holes, making trim panels, rounding panel edges. I could work without it, but the quality of the results simply wouldn't be the same.
The most convenient thing I have for speeding up tedious jobs is a combination drill with countersink that quickchanges with a phillips bit all in one unit. Drill the holes with the proper countersink and drive the screws all without touching the chuck or finding the right bit.
Thx.your best bet would be to take the screws that use use the most and take it to a hardware store and tell em that u need a countersink bit for this screw. that way you know your going to get the right one the first time....
PS, yes, i have 4 of those table saws here at the plant. you just can't get a better cut than with one of those.
http://www.sears.com/sr/javasr/product.do?cat=Power+Tool+Accessories&pid=00925824000&vertical=TOOL&subcat=Drill+Bits&BV_UseBVCookie=YesI went shopping for a tool like that but was not sure of the diameter and length of the pilot bit and the countersink. Whats the specs of yours and what size screws do you use i.e. length and diameter?
making one shortly //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifmy guide that i made from hardboard and birch
"the plant" would you own said plant?your best bet would be to take the screws that use use the most and take it to a hardware store and tell em that u need a countersink bit for this screw. that way you know your going to get the right one the first time....
I got mine at HD. Made by DeWalt. Cost like $15. Came with 3 different size bits and countersink cutters for each. Here's a link:I went shopping for a tool like that but was not sure of the diameter and length of the pilot bit and the countersink. Whats the specs of yours and what size screws do you use i.e. length and diameter?
