Whats up with my subs taking a break
Dawgriderdanny
South Ms
I had 2 jbl 12s in a ported box that sat on my back seat of my silverado. They were powered by a jbl gto amp. They hit perfectly fine at any volume or eq setting
But when space was a problem i put the 2 jbls in a double seal box under my seat facing outward.
Now when ever the bass is up high the subs will stop hitting and then come back a few seconds later. It will not do this if the volume or bass level is low. The amp is on at all times as i watch this happen.
So the amp,subs and all the settings and adjustments are the same, Just the box it smaller and seal.
Why is it doin this? And how would a box affect this
I'd go with a tinsel lead, but then it wouldn't work on low power?
Check yo wires foo.
Or maybe you dropped your impedence with the amp and you need to retune the amp
Well i think its going on protect mode but the amp stays lit green. It comes on exactly 5 seconds after it stops hitting. It stops only when the bass is loud.
I'll go check out the wiring in the box later and see if something is wrong
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Dawgriderdanny
Dawgriderdanny
South Ms
Dawgriderdanny
    May 22, 2024
    May 22, 2024
