no power
  1. D
    Audison amp not powering on - advice needed
    Hi all, I'm new here and I've come in search of some expert knowledge! I've been into car audio ever since I passed my drivers test back in 2006 and I used to dabble a lot then with amplifiers and subwoofers. Around 2015 I undertook the task of running new speaker wire through into the doors of...
  2. L
    Radio will not power
    Ok so I have a 2007 Jeep Liberty and I finally got the chance to get a new radio. I bought a boss audio system elite from auto zone and I got everything else I need. The wiring harness and such, did all the shit and connected the wires to the color it was supposed to go to and it will not power...
  3. A
    New deck pontiac g5 2008 not powering up
    Hello, Im looking for some assistance regarding my new stereo im trying to install in my 2008 Pontiac G5. I made all the correct soldering and tube shrink connections needed for my scosche gm3000fa except for a sw1 sw2 and ant cables to the new radio harness as the scosche didnt seem to have...
  4. T
    stereo wont turn on
    just tried installing a Sony MEX-N4100BT in my girlfrinds brothers 2000 chevy venture and it will not turn on head unit is brand new i have power and fuses are good i guess im wanting to know if it maybe the ground even though i have it hooked up through the wire harness if i might have to...
  5. Falloutkid90
    What happend to my sound???
    So I'm running two kicker amps (4 channel and a mono) I've had this set up for almost a year now. Today, I'm driving listening to music on the way to work and music cuts off. No sound from the speakers or the subs. I'm thinking maybe the amp turn on wire behind the head unit came lose. After...
  6. D
    New Member - Intermittent Power to Amplifiers
    Hi everyone, I have an issue with my system that I'm trying to troubleshoot. I suspect that the technician at my shop either is not good at troubleshooting or is trying to avoid a lengthy repair. My system originally consisted of an upgraded head unit, 4-channel amp, and new speakers. After a...
  7. M
    Problem getting power HELP
    So i have had my current system for about 4 months. 2 12in American Bass XD subs, Soundstream dtr1400.1 rated at 1400rms at 1 ohm (which is how my subs are wired) Recently my amp has been cutting out while driving for up to a minute. It used to snap right back on after a while. After about a...
  8. D
    Whats up with my subs taking a break
    I had 2 jbl 12s in a ported box that sat on my back seat of my silverado. They were powered by a jbl gto amp. They hit perfectly fine at any volume or eq setting But when space was a problem i put the 2 jbls in a double seal box under my seat facing outward. Now when ever the bass is up high...
  9. 3
    System Keeps Killing Amps! HELP!!!!!!!!!!!!!!
    my car is a 73 duster and i have 2 3000 w power acoustik mofo 12's. i have a 2 alternators. one for subs and one for the rest of my electronics. it is 110 amps and i have it wire to a second battery. i had a 4000 w mono-block amp hood up to them and they slammed. they worked perfectly fine for a...
