whats it all mean
fakename
http://img96.imageshack.us/img96/8170/dscf31786zg.jpg
where should i have these little boogers turned? i just got upgrading my power/ground to 1/0 knu kolossus and new rca's. somehow, i completely lost my lows. and also, before i would have it on volume 35 and it'd be slammin, but now i have to have it on about volume 50..and still no lows.
edit..by the way, i will be upgrading my spkr wire to 10 gauge on monday
are your headunits preouts stronger than 2 volts, if so change your input sensitivity thing to 2v-8v
did that, and it almost went completely quiet //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
edit..the rca thing didnt work
the only thing i lost are the lows. the mids are fine. i have no idea how to adjust this and that. i dont even know what sub-sonic means. i played with the bast boost but the lows just dont hit. could a bad ground be a problem? (amp ground)
gtfo of car audio now
sub sonic is just like your lpf...just does it at the other end. so basically it sets a cut off for how low in freq. the subs will play. if it is set high and the lpf is set low it gives you a very smap window of playable music... does that make sense at all?
fakename
fakename
earth
ngsm13
