Whats best Amp for this situation?
  • 2
blaupunkt
im pumpin two blaupunkt 12 200W rms- 600W max PCwil1200, i was looking into putting two saphire 520.1 amps. but if i wanted to put one amp for the both of them, which one would get me most power ( i want to put as much power as i can withouth blowing them=])?
Buy an Earthquake ph2 "shredder" AND WATCH THOSE PUPPYS SMOKE!!!HAHAHAHA!!
On a more serious note- mtx 500D, jbl600.1, rockford 500.1, pheonix gold "tantrum" 500.1- any of these amps will do the job nicely, they all put a out a little more than their rated power so they will have no problem maxing out your blau's 200 watt rms rating.
also, If you want your blau's to handle a little more Rms power and take a little more punishment, run them in a tight sealed enclosure( .7 to 1cft per sub )
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
blaupunkt
blaupunkt
Miami, FL
stones
    May 16, 2024
    May 16, 2024
