NEED HELP: read this PLEASE!
blaupunkt
alright, im new with the subs and stuff, i have everything exept the amps right now. i was wondering if you can push one sub with a two channel amp. the amp i wanted to but is at this website.
http://www.cardiscountstereos.com/Catalog%20Page.asp?Product+%23=SP2X520
i have two 600 WATT at 4 OHMS speakers and want to put one of these amps on each, will this work?
the speakers i have are here
http://www.sounddomain.com/sku/BLAPCWI1200
is this a good amp for this sub, will it work, and if there are better amps can u please tell me!?>!?!
ok, then what amp would i be able to get at least 500 Watts out of?
and can u exeed the max watts on speaker or are they blown?
whats the best amp for a 600 W sub?
slow down there buddy
first off, i wouldn't want to overpower those subs.
second, find a hq amp with the amount of power u need that fits your budget. It's all about what you like.
Hey man, just might wanna watch how much power you put to those.
Those subs are only rated at 200 watts RMS. Watch your gain if you
do get an amp rated at a higher rms than what the subs are suggested
to support. Most companies do under rate but you can't always be
positive!
11
499
608
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
878
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
blaupunkt
blaupunkt
Miami, FL
MeteorShower
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
