whats a cheaper but same quality sub that can go toe to toe with type r 12
will it really matter since the battery is going to be in the trunk
Unless i'm mistaken (this is my interpretation from what i've read), the 2nd battery is powered by running a wire from the 1st battery (hood battery) to the 2nd battery so yes that would matter (a non AGM battery would be sending a current to an AGM battery). You could screw with a battery isolator but you'd still have a crappy battery under the hood + that would cost you more money.
Just buy a good group 34 battery (Die hard platinum, Battery plus XS series Group 34, XS D3400......ect) with a good charger and be done with it (big 3 will also have to be done).
That is literally the easiest thing to do (trunk battery is going to require an AGM in the front and back, wiring from the front to back with possible isolator and a charger).
Or you could just get a group 34 under the hood with charger and be done with it
Crown victoria comes with a stock 135A alternator so that plus a good battery under the hood should be good for a daily driver (you won't be able to blast the Q2200 like crazy but it should still get loud enough to rattle your brain)
Normally its not advised and it "shortens" the life of your batteries but plenty of people do it often with no repercussions at all. I've done it with my corolla's duralast gold and several kinetik batteries in the trunk no problem. Mines was an 80 amp alt, even smaller than yours and it ran a 2k fine for a few years before i got my high output alt in.
good to know. i feel safer buying the battery now , im ready to get this sound systems hooked up
You did everything right except the most important part bro... prebuilt boxes gonna make the system hit weak and sound like sh*t Can't you just try and build it yourself? its easy man. I'll even design you a box. Give me your Depth x Width x height of your trunk.
home depot, buy wood, have them cut it. take it home, wood glue and screw. get a jigsaw from family friends or neighbor and cut the sub holes. DONE.
Your 3 12s in a prebuilt box will hit as hard as an 8 in a custom enclosure.
man i wouldnt know what the hell im doing when it comes to putting that thing together
now that you said something, Im bout to find someone on craiglist that can do it
Its a lot easier than you think, it just sound challenging but its easy as solving a 12 piece kids puzzle. If you do go with craigslist, link us the craigslist ad and run it by us, we can check the work and price and see if its good or not.
Serious though, let me know your trunk measurements.
well i have a 2003 crown voctoria all of there trucks are the same
ygbodybuilder10
ygbodybuilder10
United States
Jeffdachef
