What would I need
Alright, and then what subs and amp would you say I should get, I would want room to add a third sub if I wanted to, cause right now i,would only do 2 for the time being
Sent from my SM-G955U using Tapatalk
Need the box dimensions first to determine what will work
So should I just go measure out the what the size of the area would be? Before I make the box?
So it's a weird shape so it's 27 inches long by I think the image says 9, but cut that down to probably 25 long 27 wide and I think 5 deep
Definitely measure a few times and draw it out. Once you get a solid idea on the space, we can look at subs.
I would fiberglass that. Maximize the space you have.
So I am just going to go the box I posted previously, now i am just wondering what subs and amp or other stuff I sho uld get
currently I am using 4g wires for my ground and power (1-1.5ft for ground and like 16ft for my power) and no I did not sand the area for the...
101
182
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
136
484
Dayne.s
Dayne.s
US
Dayne.s
    May 19, 2024
    May 19, 2024
