what type of amp??? Is it oK
samuraibill
Ok guys here's my deal. I am about to order a pair of theelemental designs' 6.5in subwoofers for my rear deck, and I will be getting a set of 6.5in Kevlar componants from bravox audio .
My question is that can i run these off of the same amp? My trunk space is kind of limited so i would like to avoid multiple amps if possible. If this is something that i can do, what are some good CHEAP amp?
Thanks for the help!
Can you explain why you think there woud be a problem running them off one amp? Something is in your mind is illogical if you aren't sure so maybe it needs to be straightened out before you install.
samuraibill
samuraibill
Mississippi
nismos14
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
