What to set Xover At ???
pioneer
what's up...i have a sub an orion xtr 10 and i built a new box for it...the box is tuned at 38Hz
i would like to know what would be a good frequency to set the Xover on the amp at ?
the bandwidth is 50Hz-210Hz
thanks
btw i listen ot everything...rap...techno...rock and reggae
You're screwed thats way to high to crossover to a subwoofer at. The whole point of the sub is subsonic audio reproduction which is 100hz and down to me at the most. I'd buy a subwoofer amp if I were you unless your HU has a built in crossover than I would use that.
That and I thought you said 50kHz my fault. Generaly speaking subwoofer amps produce from 5hz-500hz if I'm not mistaken. So you will definitely be suffering in the sub range of bass if your amp can only reproduce down to 50hz.
LoL. Set the Low Pass filter to 80hz and you will be fine. I really need to read these questions during the day //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
set d low pass freq on the amp to 80Hz right ?
reason i asked this question is because i had a different box before which had a wider range
so i jus wanted to make sure
thanks alot
pioneer
pioneer
Trinidad & Tobago
pioneer
michigan born
    May 14, 2026
michigan born
    May 14, 2026
