What to power my interiors with
  • 5
Jace12
NY
I was thinking of going with the alpine pdx f4. I've heard nothing bad about it and it runs 100rms to all 4 of my speakers. (I have 4 alpine spr 60s and they take 100rms)
Do you think this is a good choice? If not, gimme something 250-300 that would be better if you can //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks
Not interested man. Just want some ideas to look at
Im not selling anything..lol, just giving you ideas for some other amps that are clean/lower in TDH%, and rated at /below 12v with unregulated supplies,delivering sq, along with under rated power:D
Oh lol thought you were trying to sell them! Well, what do you think about the alpine pdx f4 I mentioned before?
Alpine do make decent amps, and always have, but those specs are rated @14.4v, and Im not sure if you have a good agm battery,big 3 done with 0ga, and good supply line for the amp,and a high output alternator,that will keep you at that 14.4 volts,with the vehicle running,lights on,a/c on,radio on,at stock, you might be at 13.2,so somewhere @50-75 watts rms,.Those I showed you are under rated @11.9v@50rms, and should be anywhere to 60-75 rms at 13v,and possibly more, for a 1/3 of your buying price,and the TDH is /may be a bit less, or the same depending on which amp you choose,and take less fusing to run,being a bit easy on your electrical
Have the big 3 done with 0 gauge wire. Kinetik 1800 as main battery and DC power 270 amp high output alternator
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
469
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
364
754
Jace12
Jace12
NY
audiobaun
Brendon Jenness
    May 8, 2024
    May 8, 2024
