What to look for in a battery?
markt3307
I'm looking to get some batteries for my car, I've already got a blue top under the hood, a 220 amp Powermaster alt, along with the big 3 and 2 runs of "+" to the rear...I'll be running two Mmats 3500.1's and probably going to upgrade to something with more juice...What should I look for in a battery? CCA? Ah? I'd like to have much more reserve power than I need...Ive found a couple off brand 200 ah batteries, would they be sufficient? Thanks in advance for any input
your looking for a high ah battery someone correct me if i am wrong but if you puta 200 amp draw on a 200 ah battery your looking at a totally dead battery in 1 hr
CCA and Ca are specs where the battery is run to 7.2 volts at 30 seconds. The spec does not care that it is above 10 volts or a usable voltage to an amplifier. I would also lean towards a couple group 31 sized batteries. Something like 2 kinetik hc2400, odyssey pc2150 or Deka 9a31s
markt3307
markt3307
Bradenton, FL
basscort2009
michigan born
    May 14, 2026
michigan born
    May 14, 2026
