1996 lexus ls400 wiring harness
also when i took the factory stereo out, i saw 3 different harnesses. but in the wiring harnesses that i have found they only have 2.
so can someone explain to me what each of the 3 harnesses are?
Well here is the problem you are goinbg to run into with this car.
The car has the Pioneer system in it (Amp located in the trunk on the passenger side) and the stock speakers are 1ohm (Aftermarket HU will not take this low of a load) so if you replace the factory head unit you are going to have to bypass the factory amp and replace the stock speakers. No one makes an amp integration harness so this will have to be done.
The amp bypass is very easy on the car and replacing the speakers are as well
yeh the amp is under the passenger seat. but i planned on bypassing that anyway, because i have 2 12s and an amp to put in there. also i could easily replace the speakers as well, which might be easier cause then i could just run the new speaker wires straight to the headunit right?
Yeah that will work
Batt+ is Blue/Yellow
ACC+ is Gray
Ground is Brown
Power Antenna is BLACK/RED
The speaker wires are found in a green plug at the amp.
Left Front+ Pink
Left Front- Purple
Right Front+ Green
Right Front- Blue
Left Rear+ Black
Left Rear- Yellow
Right Rear+ Red
Right Rear- Black
Tommyb
Tommyb
North Carolina
Tommyb
