What to consider before purchasing a battery
  • 4
ckunke002
A 1400 watt car audio battery would likely be what I need, and I found this one which will fit in my battery holder and am considering buying it.
Are there any tests I need to have done on my electrical system before switching the batteries or anything like that? As long as it fits in my battery holder will it be an okay match?
Also do new batteries come charged, or do I need to buy a charger to get it to a starting charge level?
Thanks for all answers
Why are you changing batteries? And yes, you need to charge it before putting it in your car. Give it a good 24 hour trickle charge (~2A) and then put it in the next day. If your battery is low you're better off putting it on a slow charge rather than having your alt charge it, especially if it's a deep cycle
I want a new battery because my audio gear kills my battery quickly, and a weak voltage output is harder on amplifiers in the long run. I think I could get better output out of them with a new battery as well
---------- Post added at 03:38 PM ---------- Previous post was at 03:38 PM ----------
How much do car battery chargers go for?
Cooool.. would you suggest the optima or kinetic more?
i use a redtop 24/74 to start my car and use an hc2000 from kinetik in the rear. best combo for me i dont drop below 13 with 240w of ab power and 2200 of class d.
75/25 my bad
Okay sweet, i'll probably just end up with the kinetic then. On a somewhat related note, their website says to have a load test done on my current battery before buying one of theirs. Is this actually important? and what am I even looking for?
yep have a load test done at walmart or advance auto. just make sure the batt is preforming to spec. funny thing here. i got mine done at walmart and they didnt know i had more than the redtop and told me i had a very special battery //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Yea from what I've seen they are very efficient and the power handling goes down because of that and hits peak excursion easier
63
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
765
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
ckunke002
ckunke002
Portland, OR
CAT MAN
