What sub(s) with this AMP????
LightningGA
I have an Audiobahn A8000T amp and I'm looking to get a new sub. I currently have an Audiobahn AW1206T brand new in the box...never installed...but I want a sub in a sealed box do to available space. I'll most likely be selling the AW1206T for $100+shipping (just incase anyones interested).
I'm looking for something that I can run at 2ohms...so preferably a single 12" dual 4ohm voicecoil sub. I'm looking for something to go in a 1 - 1.5cu/ft or less. I can spend around 100-150 or so, hopefully I can find something on Ebay.
you can get pioneer subs for cheap, if you don't care about good SQ. there was a dual 4 ohm version awhile back that i installed that bumped hard. I think it was the TS-W2541DVC. you could probably pick one up for under 70 bucks and it uses like .70cu/ft sealed. Its a ten incher, I'm sure there is a 12 inch equivilent though.
EDIT: the 12 incher is the TS-W3041DVC
or should I just throw the AW1206T in sealed box????
What do the RE subs cost that alot of you guys rave about???
And are they recommended for a sealed box????
I wouldnt' look into RE with that kinda price range. Unless you wanted to get maybe get a used SE series. BTW the Rec. sealed range for that 1206T is .75-1.25. I would just stick with the sub you have now and put it in a 1.25cf box and stuff with 20oz for polyfill, since your amp is only 800w rms and your sub is 1100
LightningGA
LightningGA
Saratoga, NY
Elitemafia
NorthFramingham
    Jun 30, 2026
