Can a shiva
Elitemafia
I've got Shivas
Handle an 800 watt amp if the gains are turned down... Also i've looke don the Adire site, but I didn't see a clear answer to the best box set up for 2 12" shivas...
My friend has a vented 4 cu. ft box tuned to 34htz laying around I can take... It fits 2 12"s
if the amp puts out 800 @2ohms it should be nice, if it's rated at 1ohm you won't get full power. wiring the voice coils on each driver in parallel should get you at 2ohms with 2 shivas.
I have read that, I obviously wouldn't turn the gains past 75 percent... There are people that have Shivas running on JBL 1200.1's no problem.
Also will they sound decent in the box I described above?
That specific box will make sound. I have no experience with Shivas, so all I can say is try it. It's not like the wrong box is going to automatically kill a sub, unless you're really tryin' to kill it in the first place. The worst it could do is sound bad.
Elitemafia
I've got Shivas
Elitemafia
Chicago
Elitemafia
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
