what sub?..rl-p SQ....but louder
Whats wrong with the RL-p?
Lets try and fix it.
What kinda of box do you have it in?
Ported, sealed, etc?
The RL-p should rivel an Si mag and TC-2000 for output and clarity so you wont be really upgrading in either case.
ported...2 cu ft tuned to 28hz...receiving 1000 watts rms US amps power.love the low tuning,but would like a little more out of it.Bigger box? or maybe im just getting used to it
wont i lose some of the low end going from 28hz to32hz?
Some, but you'd be louder regardless. Maybe save up and get another RL-P? Even off the same amp you'd gain a bit of volume and you could get a bigger amp if that still isn't enough.
Your box is plenty large enough for a single RL-p 12".
Is it in the trunk? that may be big problem for output.
I would not recommend going higher in the tuning frq. That will just make it sound worse and worse.
You probably need to step up to a 15" or a second 12".
x2 on the 15"
lose them 12"...
loud-n-low
i give ladies 30mm xmax
loud-n-low
upstate NY
SQBubble
