What size amp do I need?
I have 3 Audiobahn ALUM12Q's bridged togather.
Audiobahn ALUM12Q Subwoofer Specifications
Subwoofer Size 12"
Voice Coil(s) Dual
Impedance (per voice coil) 6 ohms
Peak Power Handling 2000 watts approx.
RMS Power Handling 1000 watts
Woofer Surround PHAT 1.75" EPDM Rubber Surround
Sensitivity 96.4 dB
Frequency Response 18 - 500 Hz
Top Mount Depth 5-5/8"
Cutout Diameter 11-1/8"
Wht kind of amp and what size should I get?
Will a 2000watt amp push them?
Hifonics BRZ2400.1D
this amp is cea certified and is uderrated actual out put is around 2600 and for the price you cant beat it or check out the Hifonics HFi3000D
they only make them in dual 6 ohms bud
---------- Post added at 06:32 PM ---------- Previous post was at 06:31 PM ----------
so if he has 3 it would be ideal to run them at 1 ohm
Hifonics BRZ2400.1D this amp is cea certified and is uderrated actual out put is around 2600 and for the price you cant beat it or check out the Hifonics HFi3000D
The 3000 will not do rated even if struck by lightning. The 2400 is decent and will do close to rated but for the price I would grab a aq2200d.
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
Agreed. I've used some very fine cable for +REM connections because I had it laying around and have had issues with it failing. Good quality...
That heatsink's shape, color, and plexi bottom is just like the US Amps. I like it.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Chesaning1995
Chesaning1995
Chesaning, Mi
disturbed471985
    May 24, 2024
    May 23, 2024
