What size amp do I need?
I have 3 Audiobahn ALUM12Q's bridged togather.
Audiobahn ALUM12Q Subwoofer Specifications
Subwoofer Size 12"
Voice Coil(s) Dual
Impedance (per voice coil) 6 ohms
Peak Power Handling 2000 watts approx.
RMS Power Handling 1000 watts
Woofer Surround PHAT 1.75" EPDM Rubber Surround
Sensitivity 96.4 dB
Frequency Response 18 - 500 Hz
Top Mount Depth 5-5/8"
Cutout Diameter 11-1/8"
Wht kind of amp and what size should I get?
Will a 2000watt amp push them?
they only make them in dual 6 ohms bud
---------- Post added at 06:32 PM ---------- Previous post was at 06:31 PM ----------
so if he has 3 it would be ideal to run them at 1 ohm
Hifonics BRZ2400.1D this amp is cea certified and is uderrated actual out put is around 2600 and for the price you cant beat it or check out the Hifonics HFi3000D
The 3000 will not do rated even if struck by lightning. The 2400 is decent and will do close to rated but for the price I would grab a aq2200d.
Chesaning1995
Chesaning1995
Chesaning, Mi
disturbed471985
vegang
vegang
