cory51191
Cory
is there a guide or?
i'm about to be running 2 12" Zeus subwoofers 500rms DVC. i don't know if the ones this guy is selling are the 2ohm or the 4ohm but,
-if they are the 2ohm ones i will be putting out 750rms @ 2ohm on my amp.
-if they are the 4ohm ones i will be putting out 1150rms @ 1ohm on my amp.
how should i tune the amp?
Fusion pp-am20001 (amp specs)
- 465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
- 750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
-1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
- Linked Power Ratings @14.4VDC
- 1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
- 1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
- Max Power Rating: 2000 Watts
- Max Current: 100A
- Full Rated Power Distortion (Max) 1kHz: 0.45%
- THD @ Rated Power 1kHz/100Hz: 0.3%
- Frequency Response Hz (-3dB): 10Hz - 250Hz
- Signal to Noise: >90
- Variable Low Pass Filter: 12 dB/Octave
- Bass Boost @ 45Hz: 12dB
- Input Sensitivity: 0.2 - 8V
- Input Impedance: 47K
- Fuse Rating: 25A x 4
- Dimensions(WxHxL) (inches): 10-5/8 x 2-1/4 x 19-7/8
- Max Current: 100A
